Can a 3D scanner capture minute detail of a watch case? Can 3D printer render it ?
Hello,
I have some designs in mind for both a ring and a watch. I own a ring and watch that are similar to what I have in mind. 3D scanned. For the watch, it would only be the case, I would use the existing band and mechanism and glass on the new 3D printed case. Once scanned, I will draw up my changes and have a 3D designer make the changes to the 3D model, then send them out to be 3D printed in sliver. That is my idea, but I have no idea how realistic it is. Can a typical 3D scanner capture the minute details of a watch case and can Does 3D printed silver have the smooth shiny finish desirable for a ring or watch? Would this be extremely expensive?
Please help.
I did not find the right solution from the Internet.
References: -
https://www.tiertime.com/forum/viewtopic.php?t=55998
Recycling Service Video
Thanks!
В друзьях у: 25
Голосов: 1446 / 570
spadekevin,
Your idea is unreal. You should have at least a basic knowledge of 3D jewelry production, and then generate ideas.
Thanks
Dmitri
твоя идея нереальна. Сначала наберись хотя бы базовых знаний в ювелирном 3Д, а потом генерируй идеи
Изменено: Dmitri - 26.06.2018 17:57:13
